  3. Mediathekview 14.1.0 und und korrupte History
5 Beiträge 2 Kommentatoren 404 Aufrufe
    mvuserathome
    Hallo
    leider scheint bei mir die History db beschädigt zu sein.
    Gibt es einen Weg, dies zu korrigieren ohne die History zu verlieren ?
    ERROR 2024-12-13 18:36:15,354 [ForkJoinPool.commonPool-worker-5] tab_film.GuiFilme$3 (GuiFilme.java:765) - Model filtering failed!
    org.sqlite.SQLiteException: [SQLITE_CORRUPT] The database disk image is malformed (database disk image is malformed)
    at org.sqlite.core.DB.newSQLException(DB.java:1179) ~[MediathekView.jar:?]
    at org.sqlite.core.DB.newSQLException(DB.java:1190) ~[MediathekView.jar:?]
    at org.sqlite.core.DB.throwex(DB.java:1150) ~[MediathekView.jar:?]
    at org.sqlite.jdbc3.JDBC3ResultSet.next(JDBC3ResultSet.java:83) ~[MediathekView.jar:?]
    at mediathek.controller.history.SeenHistoryController.prepareMemoryCache(SeenHistoryController.kt:110) ~[MediathekView.jar:?]
    at mediathek.gui.tabs.tab_film.helpers.GuiFilmeModelHelper.performTableFiltering(GuiFilmeModelHelper.java:76) ~[MediathekView.jar:?]
    at mediathek.gui.tabs.tab_film.helpers.GuiFilmeModelHelper.getFilteredTableModel(GuiFilmeModelHelper.java:169) ~[MediathekView.jar:?]
    at mediathek.gui.tabs.tab_film.GuiFilme.lambda$loadTable$20(GuiFilme.java:747) ~[MediathekView.jar:?]
    at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:131) ~[MediathekView.jar:?]
    at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:76) ~[MediathekView.jar:?]
    at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:82) ~[MediathekView.jar:?]
    at java.base/java.util.concurrent.ForkJoinTask$RunnableExecuteAction.exec(ForkJoinTask.java:1423) [?:?]
    at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:387) [?:?]
    at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1312) [?:?]
    at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1843) [?:?]
    at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1808) [?:?]
    at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:188) [?:?]
    ERROR 2024-12-13 18:48:09,738 [AWT-EventQueue-0] history.SeenHistoryController (SeenHistoryController.kt:175) - SQL error:
    java.sql.SQLException: statement is not executing
    at org.sqlite.core.CoreStatement.checkOpen(CoreStatement.java:63) ~[MediathekView.jar:?]
    at org.sqlite.core.CorePreparedStatement.batch(CorePreparedStatement.java:101) ~[MediathekView.jar:?]
    at org.sqlite.jdbc3.JDBC3PreparedStatement.setString(JDBC3PreparedStatement.java:387) ~[MediathekView.jar:?]
    at mediathek.controller.history.SeenHistoryController.hasBeenSeen(SeenHistoryController.kt:168) ~[MediathekView.jar:?]
    at mediathek.tool.cellrenderer.CellRendererFilme.applyColorSettings(CellRendererFilme.java:152) ~[MediathekView.jar:?]
    at mediathek.tool.cellrenderer.CellRendererFilme.getTableCellRendererComponent(CellRendererFilme.java:129) ~[MediathekView.jar:?]
    at java.desktop/javax.swing.JTable.prepareRenderer(JTable.java:5818) ~[?:?]
    at java.desktop/javax.swing.JTable.getToolTipText(JTable.java:3445) ~[?:?]
    at mediathek.tool.table.MVFilmTable.getToolTipText(MVFilmTable.java:29) ~[MediathekView.jar:?]
    at java.desktop/javax.swing.ToolTipManager$insideTimerAction.actionPerformed(ToolTipManager.java:693) ~[?:?]
    at java.desktop/javax.swing.Timer.fireActionPerformed(Timer.java:311) ~[?:?]
    at java.desktop/javax.swing.Timer$DoPostEvent.run(Timer.java:243) ~[?:?]
    at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:318) ~[?:?]
    at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:773) ~[?:?]
    at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720) ~[?:?]
    at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714) ~[?:?]
    at java.base/java.security.AccessController.doPrivileged(AccessController.java:400) [?:?]
    at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87) [?:?]
    at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742) [?:?]
    at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) [?:?]
    at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) [?:?]
    at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113) [?:?]
    at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109) [?:?]
    at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) [?:?]
    at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90) [?:?]
      mvuserathome
      Ich sollte noch sagen.
      Es ist Windows 10
        Vor den Rettungsversuchen die Datei %userprofile%\.mediathek3\history.db erst mal kopieren, dann damit:
        • SQLite recovery
        • Eventuell im DB Browser for SQLite mal öffnen versuchen, nicht dass MV da ein Problem hat?
        Fürchte aber, dass da nicht mehr alles mehr zu retten ist. Programm mal abgeschossen, was man genau aus dem Grund nicht machen sollte?
          mvuserathome
          Dummerweise scheint sich dieser Laptop manchmal aufzuhängen,
          wenn er im Tiefschlaf ist.
          Dann geht nur noch forcierter Neustart des Systems.
          Habe jetzt in den Einstellungen ‘Nie’ eingestellt für Abschaltung Bildschirm und Energiesparen
            mvuserathome
            @tvRR
            Danke, die Links haben geholfen.
            Der Db Browser konnte die Daten lesen,
            meinte aber auch zuviel Einträge im Index.
            Nun scheint die History wieder zu funktionieren.
